02-13-2016, 04:34 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
Rear End Fluid Service Notice
Hey all,
Won't be able to give too much detail on this other than what I was told by the Service department at my dealer. I took it in to schedule my first oil change and to let them know I was hearing an odd noise out of the rear end when doing low speed turns when I first Drive it that day. A rubbing or vibration is best I could explain. Drove with the tech and tried to replicate with no luck. He thinks it's only when the car is still cold. He also mentioned that they had got a service notice regarding certain RPOs of the 6gens where a noise in rear may have to require them to drain the rear end fluid, put new, drive it, drain again, and add new till the sound goes away. He couldn't remember what specific vins it was on but that they would look at either way when I leave it with them for the oil change. Last edited by Clawson; 02-19-2016 at 01:08 PM. |
02-13-2016, 06:06 PM | #2 |
Drives: 2016 camaro ss Join Date: Oct 2010
This would be new and a good thing as I had the same issue a month ago and dealer had no service bulletin about it. I ended up changing the fluid myself to get the sound to go away
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
02-13-2016, 07:03 PM | #3 |
Drives: 2015 Challenger SRT Join Date: Jan 2016
Had the exact same thing in my Challenger. I ended up draining the fluid, refilling with Mobil 1, and the sound was still there so I put in a tube of Trans-X LSD friction modifier. Hasn't made a peep since and it still lays down nice dual tracks. Some diffs just need the friction modifier, so I wonder if that's the case with the Camaro.
Mike |
02-13-2016, 07:15 PM | #4 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
What was your break in process?
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
02-13-2016, 07:25 PM | #5 |
Drives: 2016 Camaro 2SS Nightfall Join Date: Jan 2016
Same problems here.
02-13-2016, 07:26 PM | #6 |
Also acts like a locker all the time.
02-13-2016, 08:11 PM | #7 |
Drives: 2013 black 2lt with rs package Join Date: Dec 2011
Just dropped mine off to the dealer today for this exact issue.
02-14-2016, 12:42 PM | #8 |
Mine is chattering at low speed turns. I had to get out in traffic quickly so kinda spun the tires while turning and it was like a sound you'd get when it didn't have the proper amount of limited slip additive in it.
02-14-2016, 08:24 PM | #9 |
02-14-2016, 08:26 PM | #10 |
And wow well glad I'm not the only one then! But yeah I expected to have some issues with a first year car. Still love it and onto regret getting it!
02-14-2016, 08:57 PM | #11 | |
02-15-2016, 12:40 PM | #12 |
376 cubic inches of fun
02-15-2016, 09:17 PM | #13 |
Taking mine in tm for first oil change at 800 miles. I'm having the service writer to check the vin for the issue you are having
02-19-2016, 05:11 AM | #14 |
Update on my problem... mine wasnt this problem. Basically it wasn't one of the ones listed to have the issue, and after they looked into everything they could think of the sounds could be coming from they are at a standstill on what the issue is. They've contacted GM Engineering and are waiting to hear back on what else they should look for. Haven't had her since Tuesday.
Thread Tools | |
