01-17-2012, 11:33 PM | #1 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Pedders XA Coilovers Installation & Review
Pedders XA coilovers + kick ass alignment = SO MUCH FUN
Doing a ride height check - which is from the bottom of the rim to the top of the fender gap. Surprisingly, even with my split drop all four corners measured the same height. Time to throw out those big ugly OEM shocks So after the shock has been removed the rotor just kind of hangs there. It took us about 15 minutes and a few bungee cords before we figured out it'd be easier to use a jack stand. This is the top of the shock tower. Now the white ring is addition on the 2011 camaros. Apparently the black cushion that the 2010's have aren't cushy enough for the coilovers. Now the problem is that the top of the coil over doesn't fit the new cushion. Solution: dremel out part of the cushion so the coilover top fits. Turns out the white cushion is actually removable and underneath it is the black cushion that fits the black cushion. Moving on. Some pictures of the OEM shocks.......Lame We're almost ready for install SO EXCITED There installed A quick pic of the new ride height. I decided to change the ride height a bit - I was scraping the front end more often than I liked. Ended up raising the front 5/8" and the rear 3/8". Which puts me at 7/8" in front and 5/8" in back. I really like it. I'll get some more photos in the morning that's a good profile shot. It was really weird driving Kaylee home though, I was so used to the "leaning forward" feeling that the new set up made me feel like I was driving a bike built by the guys from American Chopper. Total time: a lot The drive home was AWESOME. I had the highway pretty much to myself......so I might have had a little fun. It started out with just really aggressive lane changes, but that turned into me slaloming every third white dash. Don't worry though, I used my turn signals. Taking turns is like being on a roller coaster. Like when you go down the big drop and are going really really fast, then take a super sharp turn. So you keep moving forward but the car does the other way. I got the coilovers installed at Back Street Performance in Ohio. The guys there are great, even put up with me hanging out with them in the shop and taking a ton of photos. From what I gathered its a father & son run shop, which to me means a lot. It's good to see that small mom & pop shops are still around and able to compete with some of the big companies. If you're in Ohio and ever need any kind of work done - Back Street Performance is the place to go Moral of the story: XA coilovers are worth their weight in antimatter* *current market price of antimatter is $62.5 trillion per gram |
01-17-2012, 11:41 PM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
Coilovers are the way to go. Where are the pics of your car after install? Which settings did you start off with? I'm assuming you've been through this thread http://www.camaro5.com/forums/showth...light=settings
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
01-17-2012, 11:55 PM | #3 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
Coilovers are a night and day difference over even drop springs. Can't wait to see the new profile...
You'll love your xA's. =) |
01-18-2012, 12:00 AM | #4 |
Nice write up. Great guys letting you hang out and take pics. Looks like you had fun. Oh, and I used a bucket.............. Slaloming between white lines with turn signals. Oh, and I need to get me some of that anti-matter. When the US dollar drops it will be the shiznit. |
01-18-2012, 01:13 AM | #5 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
LOL, when I did mine in my drive way, I used a 50cal ammo can.
01-18-2012, 10:36 AM | #6 |
Drives: 2014 Z28 camaro Join Date: Sep 2009
Looks nice.Back Street is a top shop for sure.
01-18-2012, 11:03 AM | #7 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Congrats I know i love my Pedders setup. Entirely different car now
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
01-18-2012, 12:41 PM | #8 |
"Camaro Joe"
Welcome to the pedders nation!
01-18-2012, 01:01 PM | #9 |
Drives: 10 1LT SIM; 91 B4C sleeper Z Join Date: Aug 2009
I used a 15 year old. I bet the bucket was quieter and didn't protest!
Pedders Pace Car Package, Injen CAI, Flowmaster AT, AAC Lighting, ZL1 fascia/skirts, RKSport Ram Air hood, vented fenders, painted stripes (Gary's Customz), Honor and Valor badged (Thank you, John)
01-18-2012, 03:01 PM | #10 |
By the way, why did you remove the yellow on the stock bearings?
01-18-2012, 03:31 PM | #11 |
Drives: 2017 ZL1 Join Date: Dec 2009
You will love the Xa's way better than drop springs. I does take a while to dial in the settings but after you do it is FUN. I would also recommend the pedders sways and sub frame inserts totally changes the car.
01-18-2012, 03:52 PM | #12 |
Because the coilover wouldn't fit on it. It's new to the 2011s
01-18-2012, 04:26 PM | #13 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Looks grate, you will love them more on wide right and left hand turns at Mach 3.
01-19-2012, 07:15 AM | #14 |
Drives: 2012 Chevrolet Silverado 4x4 Z71 Join Date: Dec 2009
I have a set of these plus swaybars/endlinks to go on and I can't wait for the huge difference they will make!
Problem is,there is no authorized dealer/installer here in Wisconsin to install these parts plus a few more possibly(none that I am aware of anyways :() And before anyone says "Install them yourself,it's easy" I am handicapped and unable to do so :( The nearest dealer/installer that I can find is almost three hours away in IL.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71. |
Thread Tools | |
Similar Threads | ||||
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 467 | 06-11-2013 09:45 PM |
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers | JusticePete | Suspension / Brakes / Chassis | 144 | 12-07-2011 03:50 PM |
What the....? | Nexus6 | Suspension / Brakes / Chassis | 88 | 11-24-2011 05:25 PM |
street review of pedders bushing inserts | camaro4mybday | Suspension / Brakes / Chassis | 8 | 05-12-2011 08:19 PM |
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! | PfadtRacing | Suspension / Chassis / Brakes | 6 | 10-21-2010 10:47 AM |
