Roto-Fab
Old 03-23-2021, 08:23 PM   #883
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I might know a shop in Knoxville TN that would take it on. They build 30's hot rods from the ground up. Send me a PM if your interested.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 04-10-2021, 03:33 PM   #884
alex91z28
Drives: 2010 1ss
I know op is 5 years old, but if anyone in or near Clarksville Tennessee that would be willing to charge this old man to do this I'd appreciate it. I can drive to you! 915-926-9745 Alex
alex91z28 is offline   Reply With Quote
Old 04-10-2021, 03:36 PM   #885
alex91z28
Drives: 2010 1ss
Anyone in or near Clarksville Tennessee that would be willing to charge this old man to do this for me? I can drive to you. I'm just currently on disability and don't have the means to do it myself. Alex 915-926-9756
Old 12-12-2023, 06:07 PM   #886
doug@theautostores
Drives: 2014 camaro lt2 convertible
Water deflector
Did you install the water deflector?If so how did you mount it? Thanks
Originally Posted by Jerry7297 View Post
Ok I am not the first person to do this but I thought I would give a little detail on how I did this. I would like to acknowledge the thread below. This is the only reason I found the part and went a head and did this. This was really not that hard but the first cuts are nerve racking. Just think about the beating you put on your engines when your haulin ass around town this is the equivalent just to your exterior lol.
http://www.camaro5.com/forums/showthread.php?t=337230
I would also like to thank member "thkfast" I asked him to give me measurements off his 2014 and he did very quickly and I don't even know him. I just saw that he had the heat extractor on his hood.
Tools needed:
Air compressor
Air cut off tool
Air saw (I used the $13 dollar one from Harbor freight)
At least one brand new air saw blade pack
Grinder
Drill
1/4” drill bit
Ratchet / socket
Tape Measure
Razor Knife
File
Torch
Sponge paint brush
Sharpie (marker)
Silver Sharpie (Optional)
Vise (Optional)
Materials needed:
1- GM 2014 Heat extractor (GM Part # 22828242)
Optional- GM- Water Deflector (GM Part # 23180572)
Painters tape
Drop cloths
Masking paper
Paint (I used Cold Galvanizing Paint)
6- M6-1.00 Nylon Lock nuts (I picked these up at Lowes they do not come with the extractor)
2- sticks of flat aluminum 3/4"X 4' (Got these at Lowes but they have at Home Depot also )
1- 2X4 (Optional)
To Do list:
1. Use one of the sides the box the extractor came in and trace the extractor to make a template.
2. Measure from the Under side of the vents to outside of the extractor. I used - .5" measure yours to double check.
3. Cut out the outside and inside of the template. Test fit the template until it fits with little play on the bottom of the extractor. (see the 1st and 2nd pic below) MORE INFO on template on this link - Post #199 & #200 http://www.camaro5.com/forums/showth...=346744&page=8
4. Measure from the windshield side of the hood down 16 -3/8” in a couple of different places and make a mark with a pencil or use painters tape to make a guide line. This is the beginning of the extractor mark. Not the hole mark.
5. Put the Template on the marks and from the edge of the hood to the top corners of the extractor measure 24-1/4” this will get you lined up very close. Also pay close attention to the front side to make sure the center line of the hood with the center of the extractor template. The side measurements are not exact you may get a little different measurements just use good judgement and center it up. Also note the measurement will be different in different areas of the extractor as it gets skimmer towards the front of the extractor.
6. Once you get the template on the mark and centered on the hood Tape the template down to the hood. and use a marker to mark the inside mark of the template. Then remove the template. (MAKE SURE ITS THE INSIDE NOT THE OUTSIDE OF THE TEMPLATE OR YOUR HOLE WILL BE TOO BIG)
7. Then tape up the hood on the inside and outside of the mark you made. Closest to the mark double tape it as you will be using the saw on that area and you don’t want to scratch your paint.
8. Then use the masking paper and tape to cover the rest of your hood.
9. Open your hood remove your engine cover use drop cloths to cover the engine fenders and the front fascia.
10. Put the 2X4 under the front of the hood use as a spacer just in case. I wanted to make sure I was a not close to any engine parts…
11. Remove your Hood liner.
12. Drill 2 holes in the top 2 corners. Use your air saw to cut out your template line. If you feel like the blade is getting dull replace it. I used about 5 blades to be sure. Some parts you are cutting through sheet metal and braces on the underneath side of the hood. Use your Air cut off tool if you want to make it through the parts with braces. I used it a lot on the front side cause you do cut into the bracing in the front of the hole and it is a little difficult with the saw. Test fit the extractor and use the grinder until the extractor sits in the hole flush and doesn’t rub on any sides.
13. Use your file and file down all burrs and edges.
14. Optional (hood is aluminum and will not rust but could corrode)- Use your choice of paint and the paint brush and paint all cut edges to make sure they do not rust. I chose the galvanizing paint.
15. Remove all painters tape and drop clothes.
16. Let the paint dry then reinstall your hood liner and close your hood. Make a mark on your hood liner through the hole you cut in your hood. A silver sharpie would work great on this. I didn’t have one on hand so I just used a black one and I was able to see the mark just fine. Then remove the hood liner again and cut out the mark. As long as you have a new blade in your razor knife this is easy.
17. Place the extractor in the hole and lift the hood. Hold your flat Aluminum up and mark it so that it goes about 2-3 inches past your hole at the front set of bolts on the extractor. Use your marker and mark the center line marks of the bolts.
18. Cut the flat aluminum the the length you marked and drill the holes out with a 1/4” drill bit.
19. Cut 2 small pieces of the Flat aluminum about 3". Drill a 1/4" hole in one side.
20. Get 2 of the M6-1.00 nuts and bolt on the aluminum pieces you just cut / drilled. Put the long piece on first then add the short ones going strait towards the front of the hood. This will hold the extractor in place for the rest of the measurements. (the short pieces going to the front hold down the front of the extractor and they are needed. I didn't put them on at first and it was tight enough in the front of the extractor. )
21. I took the 2 pieces of flat aluminum that were left and put about a 1/4 inch in a vise and heated up the aluminum and bent a 90 degree in it. Then remove it from the vise and heat it some more and use a hammer and hit it till its more like a 45 degree. Please note this step is optional you do not have to do this I just thought it was a good idea.
22. Hold the other 2 pieces up the the other extractor bolts and hook the 45 degree if you did that on the hood support beam and mark where to cut the other side. I went a little past the other side of the hoods identical support beam and mark where to cut, also mark the center of the 2 extractor bolts.
23. Cut and drill the other 2 flat pieces of aluminum, get 4 more nuts and install the pieces.
24. Reinstall the Hood liner.
25. Take the time to read through the thread, there is good info on how to use the stock rain tray. It is even removable as GM intended for track use. All this was perfected by the members on here.
26. Stand back and gaze at your hard work and drool….
doug@theautostores is offline   Reply With Quote
