12-18-2014, 04:16 PM | #15 |
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51 Join Date: Apr 2014
I run 91 (In Oklahoma as well) and I am modded (See below) and I have no knock at all...Naturally the car has a tune on it and I use the Torque Pro App on a Tablet when I drive the car.
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
12-18-2014, 04:55 PM | #16 |
Drives: 2013 ZL1 Join Date: Mar 2013
No that is not a silly question. I was driving back from OKC tuesday and got within 30 miles of home and the dashlogic quit working as I was driving. I reached down with it still plugged in and moved the switch to 3 and did not touch it again. Today I pulled it out and moved it back to 1 and plugged it back in and wala,it is now showing 0.0 knock. I guess that was all I needed to do so I think I am good now.We shall see.
12-19-2014, 12:22 PM | #17 |
Drives: 2018 Summit White Camaro 1SS Join Date: Mar 2014
How many degrees are you seeing with "massive" knock?
'18 Satin White Vinyl Wrapped 1SS, 6MT, Low Gloss Black Wheels, NPP Dual Mode Exhaust
Added: Diode Dynamics Black LED Sidemarkers, GM Dark Finish Tailights, GM ZL1 Black 3rd Brake Light, Black Plastidipped Bowties(front/rear), AFE Dry Drop In Filter, 12mm Spacers(front/rear) |
12-19-2014, 12:39 PM | #18 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
What have the outside tempertures been when you experienced the knock? In colder weather, your calibration adds additional timing based on your Intake Air Tempertures.......Just like with hotter IATs subtracts timing from your main tables.
12-19-2014, 01:21 PM | #19 |
The chances for higher knock would be in warmer weather?
12-19-2014, 04:28 PM | #20 |
Hot weather does play a factor and that's what most people consider, but under 50 degrees IATs you're adding up to 4-5 degrees of additional timing for part throttle strategies.
12-19-2014, 06:02 PM | #21 |
Its been 30's- 50's here in the last week here in Oklahoma...
12-19-2014, 07:15 PM | #22 |
For those that have been asking the timing I was seeing from my dashlogic has been 36 degrees and the knock went up to around 7.4 I think. Now like I said in the above post I am not getting any knock since I pulled the dashlogic out and waited a minute and plugged it back in.I then started the car and went down the road and got in it pretty good and it shows 0.0 knock now and the timing is still showing 34-36 degrees.
12-20-2014, 08:30 AM | #23 | |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Bryan 2018 ZL1 M6
12-20-2014, 09:01 AM | #24 |
FWIW, when I ran 91 octane(all we have here), I saw 6 degrees of KR at part throttle. Since adding Torco to get approximately 93/94, I haven't seen more the 2 degrees of KR at part throttle and 0 at WOT. My only mod is a rotofab CAI
12-20-2014, 12:44 PM | #25 |
12-20-2014, 12:46 PM | #26 |
If you're on the stock tune, I don't see how the computer would allow 36 degrees of timing at WOT?
Thread Tools | |
