01-28-2014, 09:50 AM | #15 |
Drives: 2000 Camaro SS Join Date: Feb 2010
01-28-2014, 02:30 PM | #16 |
Drives: 11 SS Join Date: Oct 2013
Good write up, add this to the buy list lol
01-28-2014, 03:05 PM | #17 |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
So it looks like this scoop occupies the same space others have used for front brake cooling ducts/hoses. I want both, ideas?
01-28-2014, 05:49 PM | #18 |
There would not be a bolt on solution but it is something that could be done relatively easily. Either mounting the duct to the rear panel of the scoop or figure out a away to run it all the way up front next to the scoop. |
01-29-2014, 10:42 AM | #19 |
Drives: BMW E92 M3 ZCP Join Date: Jan 2014
Thanks for this thread! Ordered my CAI, scoop and washer bottle relocate from Apex last night. As well as an Elite catch can and VMAX Throttle Body.
01-29-2014, 03:21 PM | #20 |
Drives: SSICKO Join Date: Jul 2010
Just ordered my set up
Slowhawk Performance Built & Tuned
01-29-2014, 06:09 PM | #21 |
01-30-2014, 09:57 PM | #22 | |
GM is in my blood..
Drives: 2011 IBM 1SS/RS LS3 Join Date: Aug 2013
Thanks APEX for making such a stout product. Once I get my exhaust stuff worked out, I plan on making a video relating to Intake Air Temps... and how this scoop affects them with my setup. Scott |
02-11-2014, 09:46 AM | #23 |
Thank you. I am interested in seeing your video.
05-22-2017, 08:10 AM | #24 |
Drives: 2015 Camaro LFX A6 Join Date: Nov 2015
Mine is supposed to arrive today. Cant wait to get it installed. Thanks for the write up and pics. Will definitely help the install.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
05-22-2017, 09:24 AM | #25 |
Drives: 2018 GT350 Join Date: Nov 2011
Is the increased airflow enough to knock a tune off?
Off to the Dark Side
05-22-2017, 09:27 AM | #26 |
Good question. Was thinking about that myself. Ill be sending an updated data file to Overkill once installed.
Will - if you're reading this, share your thoughts.
05-22-2017, 10:07 AM | #27 |
Drives: camaro ss\rs Join Date: Jun 2014
of course not
btw isn't apex out of business?
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
05-22-2017, 10:31 AM | #28 |
Instagram: Sangstah
I doubt you need a retune for an air scoop.. This is on my must do list, will this work for the 14-15 models as well?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
Thread Tools | |
