03-17-2024, 09:13 PM | #1 |
Drives: 2013 Chevrolet Camaro 2SS/1LE/RS Join Date: Dec 2023
How to Replace Lifters - Guide
Hey everyone, I know that replacing the lifters seems like a simple process but when it comes to DIY I want to make sure that I do everything spot on.
I am doing a cam swap and upgrading the springs, rods, oil pump, etc. when I do so. My motor has 32,000 miles on it. I have all of the resources to do everything except pull the heads and replace the lifters and trays. I have found videos online of people doing so but they are very brief. Are there any guides/tutorials available that provide pictures and step-by-step instructions the way robertway did his DIY: LS3 Camshaft Install guide? I have printed his off to use as a reference when I do the cam install but I don't have anything for the heads and lifters. I would appreciate any insight. Thanks guys. |
03-28-2024, 11:32 AM | #2 | |
Drives: 2015 SS, 2006 CTS-V (wrecked...) Join Date: Jul 2017
Here's great video on removal if the heads:
Assembly is essentially the opposite. Head torque sequence is a bit of a challenge in the car, I just did it a couple weeks ago. You will need an angle gauge, or a digital angle torque wrench. I used the instruction guide from Trick Flow for installation: https://www.trickflow.com/parts/tfs-...nstructionArea Removing the liters is super easy with a magnetic pick-up tool, and the trays come right out with a couple 10mm bolts. Then new lifters drop into place, piece of cake. Most all lifter manufactures recommend soaking in oil before installation. The BTR lifters I used came in a convenient tray that I just poured the oil into. If you are doing all of this, might as well do a trunnion upgrade too! |
03-28-2024, 03:12 PM | #3 |
If I was you I would invest in some arp head bolts or studs so you don't have to mess around with the tty factory bolts. They are kind of pricey but I never liked the tty bolts and the arp are reusable.
03-28-2024, 04:01 PM | #4 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
This is a detailed write up for removing/replacing heads, from here on the forum. The write up is similar in style to the famous cam swap DIY.
https://www.camaro5.com/forums/showthread.php?t=556941 |
