dave@hennessey
Old 08-05-2013, 10:21 PM   #1
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
HELP! wrong screws for door panel??!
I bought these I swear it's what I read on a thread from here?
Anyways it seems the top were just too small and wouldn't hold trim down. Did I get the wrong ones?
Sent from my iPhone using Tapatalk 2
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 08-05-2013, 10:23 PM   #2
TwentyTen2SSRS
Drives: 2010 2SS/RS
Does anyone have a link to the right ones to buy?
Old 08-05-2013, 11:17 PM   #3
TwentyTen2SSRS
Drives: 2010 2SS/RS
Bump please!
Old 08-05-2013, 11:32 PM   #4
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Drives: 2011 1LT Synergy Green
Try the same size in a Truss Head , or use a washer .If the screw isn't holding in the hole you might have to go one size bigger. I had to make to trips to the hardware store myself...Good luck
BIO-HAZARD is offline   Reply With Quote
Old 08-05-2013, 11:45 PM   #5
TwentyTen2SSRS
Drives: 2010 2SS/RS
Perfect. It screwed in perfectly tight I'm guessing the head on it was just not big enough to lock down the label so holes from panel popped out. I'll look for truss heads
Old 08-06-2013, 10:21 AM   #6
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Hey Just find a real thin washer , or a rubber washer to put on each screw , I remember I couldn't find any Truss Heads with out a point . if you use a pointed screw it could go through the panel so you would have to snip the point off okay ...I ended up using washers on mine Lock ones work well...hope this helps .
Old 08-06-2013, 11:14 AM   #7
TwentyTen2SSRS
Drives: 2010 2SS/RS
Yeah that sounds perfect. Ill look for some washers today. I made a mistake on one spot and have a small indent as if screw was going to pop through luckily I caught it I'm time!
Old 08-06-2013, 11:19 AM   #8
TwentyTen2SSRS
Drives: 2010 2SS/RS
Is this the replacement for the inner part of the door? http://store.gmpartshouse.com/parts/...=Outer%20panel
Old 08-06-2013, 12:34 PM   #9
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
That looks like the outer door skin?
Are you looking for the panel that you vinyl covered blue?
http://store.gmpartshouse.com/parts/...agramCallOut=1
13blackLS is offline   Reply With Quote
Old 08-06-2013, 01:14 PM   #10
TwentyTen2SSRS
Drives: 2010 2SS/RS
No I'm looking for the inner for panel that surrounds the part I painted blue
Old 08-06-2013, 02:48 PM   #11
13blackLS
13blackLS's Avatar
The link i posted is for the entire panel...just look at the options cause some are with abl..some are for premium sound...etc....see which one is for basic door panel...i dont think you can order the surrounding part alone....i could be wrong though
