04-09-2017, 10:47 PM | #1 |
Drives: 1sadclutch Join Date: Dec 2012
DSE Front / Rear Drop Springs
DSE Drop Spring 1.5" Drop - P/N: 031131 @ 220 lbs/in. x2
DSE Drop Spring 1.5" Drop - P/N: 041812 @ 425 lbs/in. x2 DSE Springs are on order. Waiting for packing confirmation. I suppose it is a fair question to ask: Do I need to upgrade Rear Shock Mounts to 1LE? I'm going to pair the springs with Bilstein B6. Thank you. |
04-10-2017, 02:43 PM | #2 |
Also: Do I need to replace the strut bolt and strut nut when going aftermarket?
04-10-2017, 06:50 PM | #3 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Just had mine installed in the ZL1, was direct replacemnet... same springs, no further parts needed
04-17-2017, 09:22 PM | #4 |
04-19-2017, 12:55 PM | #5 |
Alignment currently out of wack. Driving home felt an incredible difference in compliance from all four struts. DSE springs mostly tame on freeway and turning. I will have more information when alignment is complete tomorrow.
04-19-2017, 02:31 PM | #6 |
Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
Looks great! Did you measure the front and rear ride heights before installing the DSE coil springs? I ask because it doesn't appear to be a 1.5" drop.
04-19-2017, 02:46 PM | #7 |
I did not measure heights unfortunately. It looks to be about a conservative 1" drop. I do feel like we could have gone lower but with this non adjustable setup I am content. The guy at the shop unknowingly topped my coolant without permission so my main concern is bubbles. I'll revisit that dilemma at alignment tomorrow.
04-22-2017, 07:56 PM | #8 |
Drives: 2013 1LE Join Date: Jan 2013
What is your impression of the ride after the alignment? Looks good.
Last edited by Abdi; 04-22-2017 at 07:57 PM. Reason: I found the answer to my question. |
04-23-2017, 03:24 PM | #9 |
The ride was a great improvement through corners and acceleration. Shifting through gears in straight line also had improvement. I am able to carry much more speed through corners and have more feedback from the rear. I do feel that I will need to upgrade sway bars now, as I felt that this was beginning to lack in comparison to the new ride and ride height.
