13.07 LFX thanks to NYTREX TRIPLE THREAT system
OK,
So I keep getting asked how did I get my 2012 2LT RS to run in the 13.0s. Here is the breakdown: Stock 14.30 @ 98mph GMPP mufflers $850.00 14.24@ 99.3MPH CAI systems intake $325.00 14.16@ 100.26MPH Trifecta tune ( group buy ) $325.00 14.05@ 101.21 ( no data logging done yet ) Nytrex Triple Threat system $850.00 13.07@ 107.67 ( need some tires and a posi unit to see it's full potential now ) :burnrubber: I love what this system has done for my car. I still get 30mpg, easy as stock to drive and power only when I want it. Don't need premium fuel all the time. Didn't have to wait for weeks to get my car back. One hour of install time for one second+ of ET. Easy to remove to go back to dealer if need to, no cutting of wires for installation. I even mounted my bottle brackets on top of the spare tire cover with the insert that come in the kit. I just wanted to share my road to 13.0 and hope it helps someone else trying to enjoy life in the fast lane. It is not the fastest LFX out there but it is a hell of a fun ride for me. I hope you are enjoying your GEN5 as much I am mine. |
Can't beat nitrous for fast HP!!!
Nice, 12's will be soon :thumbsup:
You helped me get there Juiced, great deal and quick delivery of my CAI.
Is it really that easy to do the install yourself? I would Love to do it myself but feel that one little mistakr could be catastrophic so i get a little scared lol.
Btw, what components do you have on your system? Purge, bottle heater? Did you have to do any adjusting to the tune or something like that to run the nitrous safely? |
The system IS that easy to install, comes with purge solenoid, :w00t: with pressure gauge but no bottle heater. All you need is to fill the bottle when you get the kit and everything else is there. Every car out there can use a good tune to help run better. This system can be run on a stock engine without a tune. I have helped two other folks install the kit while at car meetups. If was fun watching the crowd look on as it was being done. Only the feed line had to be completed later. I did not want to crawl on the ground than get back into my camaro dirty.
Bottle heater, I am using an old Gerbrings electric vest for my heater. It has it's own battery, so I don't drain the car. Does it work as good as a heater made to warm the bottle NO but it does decent for 99.00 and it hides the bottle some too. Than I get to wear it also on cold nights too. I am looking to add a controller to my system in the future so I can use it right from the hit of the throttle without blowing away my tires. Quote:
Thank You.
Great run!!! Following your progress closely.
I started my install of the Ny-Trex system yesterday and should have it all done before week end. Easy install but since I am doing it at my own shop I am taking it very slow!! http://i329.photobucket.com/albums/l...612_230208.jpg http://i329.photobucket.com/albums/l...612_222320.jpg http://i329.photobucket.com/albums/l...609_151024.jpg Thanks for your help with the questions!!! |
What kind of fingerprints does the system leave if I were to pull it to go into the dealer?
Still a little nervous on voiding my warranty so soon. |
The Ny-trex system leaves little to no fingerprint. There is no wire splicing necessary. A small slice through the steering column boot gets the two-wire harness through the firewall. It can be very small, as the rubber will open to accommodate the harness. The bottle mounting is the only place that drilling might be necessary. The reason I say “might” is because some have made a board or plate for the trunk area on which they have mounted the bottle. So, the fingerprint can be virtually eliminated!
I need one of these kits lol... Been wanting some nitrous for quite some time
I used the top section of the spare tire cover to mount my bottle brackets. It is very sturdy and does not show when the brackets are removed. This system is easy to install and remove without leaving anything that can be directly placed at the system. You will also find that NYTREX has great customer service. I'm waiting for a little cooler weather and some healing time from being in a friend's car accident. :character0182:
Then off to the drag strip again, I'm thinking about adding a nitrous controller to my setup. Will keep everyone posted I want that 12 second ET. Quote:
Thank you CiscoBee. Have you got your system fully in yet?
